Hey,
I have a publishing plugin working fine, the only thing that I am missing is the versioning, I have tried to set item.properties["version_number"] or item.properties["version"], but the version_number field in Shotgun is always set to 1. Do you have any idea why ?
Thanks a lot !
Cheers
Lucas
Hey Lucas
If your hook is inherited from the app’s publish plugin, then it should take the version from "publish_version":
Hopefully applying the value against that key on your item properties should give you what you’re after.
Cheers
Phil
Hey,
Thanks a lot, that’s exactly what I needed
Cheers !
