I’ve begun the process of creating a PyTest unit testing suite for an in-house Python library which interacts with Shotgun via the shotgun_api3 (currently using version: 3.2.4)
In order to keep the test data isolated from our live database I discovered the shotgun_api3.lib.mockgun.Shotgun object and have been using this.
I have encountered a few alarming deficiencies in mockgun.Shotgun.
mockgun.Shotgun().update()is completely missing the argument formulti_entity_update_modes- rendering multi-entityadd/removeupdates ineffective - On
mockgun.Shotgun().create()when setting entity / multi-entity field values to the short-form value dict of another entity eg:Task-{"entity": [{"type": "Asset", "id": 1}]}
For an example on #2 - consider the following:
import pytest
@pytest.fixture
def isg_conn():
import shotgun_api3
sg_conn = shotgun_api3.Shotgun(SG_URL, *API_CRED)
tmp_dir = 'D:/Temp/testing/shotgun'
schema_file = tmp_dir + '/shotgun_schema'
schema_entity_file = tmp_dir + '/shotgun_schema_entity'
from shotgun_api3.lib import mockgun
mockgun.generate_schema(sg_conn, schema_file, schema_entity_file)
mockgun.Shotgun.set_schema_paths(schema_file, schema_entity_file)
yield mockgun.Shotgun(SG_URL, *API_CRED)
def test_create_entity_links(isg_conn):
sg_project = isg_conn.create('Project', data={})
sg_asset = isg_conn.create('Asset',
data={'project': {'type': 'Project', 'id': sg_project['id']}},
return_fields=['tasks'])
assert sg_asset['tasks'] == []
sg_task = isg_conn.create('Task',
data={'project': {'type': 'Project', 'id': sg_project['id']}, 'entity': sg_asset},
return_fields=['entity'])
expected_sg_task_asset = {'type': 'Asset', 'id': sg_asset['id']}
assert sg_task['entity'] == expected_sg_task_asset
updated_sg_asset = isg_conn.find_one('Asset', [['id', 'is', sg_asset['id']]], ['tasks'])
expected_sg_asset_tasks = [{'type': 'Task', 'id': sg_task['id']}]
assert updated_sg_asset['tasks'] == expected_sg_asset_tasks # Failed Test: AssertionError: assert [] == [{'id': 1, 'type': 'Task'}]
There seems to be no account of some necessary logic when it comes to working with entity / multi-entity fields and the related EntityType_field_Connection objects.
Is this something others have encountered?
Is there any plan to further develop shotgun_api3.lib.mockgun to be fully-featured?
