CGSoup
1
For configurations that are on our local network I can use an Automator script to launch PS from the OSX Dock.
export SHOTGUN_LOAD_FILE_ON_OPEN="$@"
/Volumes/Production/Shotgun/PipelineConfigurations/Toolkit/tank photoshop_cc_2019
Works great, except for distributed configurations.
Is there a way, via command line to access tank from a distributed configuration so I can do something similar?
Daniel
You would need to bootstrap the tk-shell engine and run the launcher from there. That should work OK from an automator script I would think.
This guide covers bootstrapping and launching an app, should it should be exactly what you need:
CGSoup
3
Spectacular! Took all of 10 minutes. Passing the dropped file to the envvar still works too.
Now I just need to set the context first based on the dropped path.
Thanks again Philip!
Daniel
