ImportError : No module named _sqlite3 when initializing sgtk
This started showing up in the last couple of days on the render farm
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\sgtk\__init__.py", line 16, in <module>
    import tank
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\tank\__init__.py", line 113, in <module>
    from . import commands
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\tank\commands\__init__.py", line 11, in <module>
    from .tank_command import list_commands, get_command, SgtkSystemCommand
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\tank\commands\tank_command.py", line 20, in <module>
    from . import folders
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\tank\commands\folders.py", line 11, in <module>
    from .. import folder
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\tank\folder\__init__.py", line 16, in <module>
    from .operations import process_filesystem_structure, synchronize_folders
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\tank\folder\operations.py", line 17, in <module>
    from .folder_io import FolderIOReceiver
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\tank\folder\folder_io.py", line 22, in <module>
    from ..path_cache import PathCache
  File "z:\_pipeline\shotgun_config\lnk\install\core\python\tank\path_cache.py", line 18, in <module>
    import sqlite3
  File "C:\Program Files\Thinkbox\Deadline10\bin\Lib\sqlite3\__init__.py", line 24, in <module>
    from dbapi2 import *
  File "C:\Program Files\Thinkbox\Deadline10\bin\Lib\sqlite3\dbapi2.py", line 28, in <module>
    from _sqlite3 import *
Apparently sqlite3 is imported from Deadline’s libraries. Is that a version incompatibility of some sort? The built-in Python is also 2.7.
Hi @mmoshev the above issue was solved actually am also facing the same i cant find the solution
I don’t remember if there was a specific solution. You need to look at your PYTHONPATH and see where sqlite3 should be loaded from. This was way back with Python 2.
