Implement per-shot LUT in rv package
Hey Ashish,
Thank you for messaging us!
If you take a look at the Starting With OCIO guide, there’s a starter script called rv_ocio_setup_sample.py. If you download it, you can see how to set context per-node.
For example, setting up the Look pipe group:
    elif (nodeType == "RVLookPipelineGroup"):
        # If our config has a Look named shot_specific_look and uses the
        # environment/context variable "$SHOT" to locate any required
        # files on disk, then this is what that would likely look like
        result = [
            {"nodeType"   : "OCIOLook",
             "context"    : {"SHOT" : os.environ.get("SHOT","def123")}
             "properties" : {
                 "ocio.function"     : "look",
                 "ocio.inColorSpace" : OCIO.Constants.ROLE_SCENE_LINEAR,
                 "ocio_look.look"    : "shot_specific_look"}}]
Note that context here is grabbed from the environment variable that is set:
However, instead of the environment variable, you can set up a function to parse your metadata and set the context.
Hope this makes sense!
Thanks,
Alexa
