How do I import custom modules into a hook?
Hey Anthony!
If the code in your module is something that you might want to use across different hooks in your config, you might want to consider putting it into a Toolkit framework. if you choose to go that route, you can learn how to use the Hook class’s load_framework() method in this post:
If you’d rather just use Python’s import, you’ll need to use sys.path.append() to append the current folder to your Python path, so that the import command knows to look there. You can see an example of sys.path.append() in action here
