Getting published ids from parent items in the publish tree - multipublish2
Hi all
I have some chained publish items and I need to extract the publish data from an already published parent item which will affect the publish of my current item. How can I get that info? Id ect
many thanks!
Hi Sam
Here are some methods on the PublishItem that I think will help you achieve what you are after.
Does that help?
Phil
Hi Phil
Thanks for your response, I am ok with navigating the publish tree
It is more a case of knowing which specific properties are returned after a publish
So I can grab the shotgun id for the published file entity of the parent publish
It’s a little tricky to interrogate this interactively as this is all handled by the base publisher
many thanks!
Sam
please disregard - I logged the parent properties and found the info I needed:
for future ref:
a property called sg_publish_data contains the publish file info
many thanks
Nice find!
There isn’t a specific list of standard properties, it depends on what the plugin decides to store.
The property you found is getting set in this hook:
excellent thanks Phil!
