Avoid character escape in tk-shotgun engine (web page) command output
For trivial commands attached to entities from the web pages, logging info messages is great.
However, many character escapes appear on that output, even for something as simple as a single quote.
This is happening post the app processing. Checking string length in the app shows its not quoted there. Perhaps this is XML encoding between the shotgun engine and the web page javascript?
How can we prepare output to avoid character escapes in “command output”?
Hi @Rhea_Fischer – can you provide a screenshot of what you’re seeing? Thanks!
Sorry just saw this… I’ll get something together for us.
Hi @tannaz, this may only happen when debut mode is enabled. If so its interesting but not critical.
I have the same, it’s quite annoying actually!
Hi all – Just wanted to let you know I’ve put in an internal ticket to track making this output more readable. I’ll let you know when there’s news.
An I can confirm it seems to only happen when debug is enabled.
Yup, I have this too. I think this has been raised before so should already have an internal ticket for it?
Any update on this?
Building tools for production that output unreadable logs is very unhelpfull…
Is this still an issue? Has anyone figured out a workaround?
I’m making sure I don’t info print anything.
