I’m trying to make sure OpenColorIO Basic Color Management package is loaded when launching an RV session.
This seems to run fine
rvpkg -optin "OpenColorIO Basic Color Management"
But launching rv afterwards doesn’t autoload the package unless I had it loaded in a previous RV session. To test this, make sure the package is unloaded, close down rv. Now try to autoload it with these commands and run rv. It doesn’t autoload the package.
When running it again I get:
# ERROR: C:/openrv/plugins/Packages/ocio_source_setup-2.4.rvpkg is not an optional package -- ignoring
It also doesn’t work if I do it with the explicit package name:
rvpkg -optin "ocio_source_setup-2.4.rvpkg"
However when launching rv afterwards it’s still not loaded:
The rvload2 file shows:
ocio_source_setup,ocio_source_setup-2.4.rvpkg,nil,nil,nil,true,true,4.0,false,1.0.0
Which according to this makes it:
from dataclasses import dataclass
from typing import Any
@dataclass
class PackageLoad:
package: str
menu: str
shortcut: str
event: str
loaded: str
active: str
rv_version: str
optional: str
requires: Any = None
line = "ocio_source_setup,ocio_source_setup-2.4.rvpkg,nil,nil,nil,true,true,4.0,false,1.0.0"
state = PackageLoad(*line.split(","))
print(state)
# PackageLoad(name='ocio_source_setup', package='ocio_source_setup-2.4.rvpkg', menu='nil', shortcut='nil', event='nil', loaded='true', active='true', rv_version='4.0', optional='false', requires='1.0.0')
print(state.loaded)
# true
Which seems to say that it’ll be loaded, but it doesn’t.
How can I make sure the package is set to load before I launch RV?
