A new version of tk-vred has been released!
Welcome to the release notes for this Engine. Below you will find an overview of all the changes we did for each release. We try to be as detailed as possible and include all bugs we have fixed, features we have added and things that may have changed. If you have questions about a particular release, don't hesitate to contact our support team!
v2.1.2
Replacing shotgunsoftware urls with Autodesk Knowledge Network and ShotGrid Developer Documentation pages.
v2.1.3
Improvements * Added the ability to choose either a 2D or 3D Version for the Upload Version for Review Publish Plugin * Improved the workflow when a file is saved outside of a valid template and then a Publish is performed * Improved docking behaviour for launch_at_startup with multiple SG Apps
Fixed Bugs * The menu_favourites were not refreshing as expected
v2.1.4
  • Updated brand icons.
v2.1.5
2022-Oct-24
Improvements * Ability to run the tk-vred Engine in batch mode to support background publishing workflows * Toolkit app dockable UI enhancements * Initial release of tk-multi-data-validation support
v2.1.6
2023-June-05
What's Changed
  • VRED Presenter is not showing the panel
  • VRED "Begin file versioning" publish plugin fails in the accept() method
  • Can not publish from VRED with basic config
Full Changelog: https://github.com/shotgunsoftware/tk-vred/compare/v2.1.5...v2.1.6
v3.0.0
2023-Jul-06
What's Changed
  • Support Qt6/PySide6 for VRED 2024
Full Changelog: https://github.com/shotgunsoftware/tk-vred/compare/v2.1.6...v3.0.0
v3.0.1
2023-Oct-27
  • VREDPy improvements and documentation link updates.
v3.0.2
2023-Nov-03
  • Update minimum support for VRED 2024.
v3.0.3
2023-Nov-15
  • Update support for VRED 2024.2.
v3.0.4
2024-Mar-11
  • LMV translation update and improve thumbnails
  • ShotGrid menu consistent style with VRED menus
  • Qt styling for PySide6
  • Support open published file SG Toolkit Action with VRED
  • Add wire files as upstream dependencies when referenced
v3.2.0
2024-Apr-16
Add custom actions to VRED Breakdown2 and bug fix.
v3.2.1
2024-Apr-25
Fix importing multiple files at once.
v3.3.0
2024-May-21
Update Data Validation UI based on VRED events.
v3.4.0
2024-Jun-20
Pyside and Qt4 code cleanup
v3.4.1
2024-Sep-6
Bug fixes and update minimum supported VRED version
Details
  • Fix breakdown hook
  • Ensure panel app is visible on open
  • Run mogrify to strip the problematic profiles
  • Show progress dialog when importing files async
  • Update min supported logic to avoid dialog pop up
v3.5.0
2025-Mar-07
Improvements, bug fixes, new developer docs
Details
  • New Loader2 action to import environments
  • Update FPT Desktop find VRED software routine for Windows 11
  • Fix FPT Panel Create Smart Reference action
  • Remove Python 2 support
  • New developer docs https://developers.shotgridsoftware.com/tk-vred/
v3.5.1
2025-Mar-11
Removed Python 2 code.
v3.5.2
2025-May-08
What's Changed
  • Update min supported version to 2026 by @staceyoue in https://github.com/shotgunsoftware/tk-vred/pull/133
Full Changelog: https://github.com/shotgunsoftware/tk-vred/compare/v3.5.1...v3.5.2
