Task order within a Pipeline Step seems random
Hi! I’m using Flow Production for the first time, and I have a question about the task order within a pipeline step.
I’m using multiple tasks within the same pipeline step to represent different phases of work on a shot. However, the tasks don’t appear in the order I defined. In some cases, the order is even reversed, and with more than two tasks it seems almost random.
To clarify, I’m referring to the order of the tasks inside a Shot Task Template, not the order of the Pipeline Steps themselves. I’ve already arranged the tasks in the Shot Task Template in the correct order, so I expected them to appear that way, but they still don’t.
Am I doing something wrong, or is there another setting that controls the display order of tasks within a pipeline step?
Maybe add your sort order within the pipeline stage, right click and force the sort based on that field, then hide that column and save the page?
It worked! Thank you so much, Kim!
