RV Silent Install query and RV 7.5.1 msi query?
Hi in terms of msi the way I got is if you run the exe but don’t do any of the next steps apart from run go to temp you should see it has extracted a msi file there but seeing as shotgun have now have msi installer without doing this you should use it instead this was just to explain for older version of rv msi install. rv licence
