We are using a distributed configuration and one of the artist is having this issue loading a project which works for others
The error is the following:
No module named ‘tank_vendor.six.moves’
File “C:\Program Files\Shotgun\Resources\Desktop\Python\bundle_cache\app_store\tk-desktop\v2.8.5\python\utils\bootstrap_utilities.py”, line 216, in start_engine
return manager.bootstrap_engine(“tk-desktop”, self._project)
File “C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\site.basic.desktop\cfg\install\core\python\tank\bootstrap\manager.py”, line 487, in bootstrap_engine
tk = self._bootstrap_sgtk(engine_name, entity)
File “C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\site.basic.desktop\cfg\install\core\python\tank\bootstrap\manager.py”, line 1100, in bootstrap_sgtk
tk, user = config.get_tk_instance(self.sg_user)
File “C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\site.basic.desktop\cfg\install\core\python\tank\bootstrap\configuration.py”, line 127, in get_tk_instance
if self.swap_core_if_needed(python_core_path):
File “C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\site.basic.desktop\cfg\install\core\python\tank\bootstrap\configuration.py”, line 220, in swap_core_if_needed
CoreImportHandler.swap_core(target_python_core_path)
File “C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\site.basic.desktop\cfg\install\core\python\tank\bootstrap\import_handler.py”, line 92, in swap_core
import tank
File "C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\p355c331.basic.desktop\cfg\install\core\python\tank_init.py", line 112, in
from . import authentication
File "C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\p355c331.basic.desktop\cfg\install\core\python\tank\authentication_init.py", line 35, in
from .shotgun_authenticator import ShotgunAuthenticator
File “C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\p355c331.basic.desktop\cfg\install\core\python\tank\authentication\shotgun_authenticator.py”, line 13, in
from .sso_saml2 import has_sso_info_in_cookies, has_unified_login_flow_info_in_cookies
File "C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\p355c331.basic.desktop\cfg\install\core\python\tank\authentication\sso_saml2_init.py", line 15, in
from .core.errors import ( # noqa
File "C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\p355c331.basic.desktop\cfg\install\core\python\tank\authentication\sso_saml2\core_init.py", line 15, in
from .sso_saml2_core import SsoSaml2Core # noqa
File “C:\Users\fermi\AppData\Roaming\Shotgun\exodoanimation\p355c331.basic.desktop\cfg\install\core\python\tank\authentication\sso_saml2\core\sso_saml2_core.py”, line 52, in
from tank_vendor.six.moves.urllib.parse import urlencode
ModuleNotFoundError: No module named ‘tank_vendor.six.moves’
No idea how to solve this, have deleted local cache and local bundles, also reinstalling SG desktop
Any ideas to solve this?
