Darshan Hiranandani : Issue with Creating Filesystem Structure using SGTK - Any Suggestions?
Hi all,
I’m Darshan Hiranandani, encountering an issue while trying to use the create_filesystem_structure() function in SGTK to create and register directories for an asset. Here’s a simplified version of the code I’m working with:
mgr = sgtk.bootstrap.ToolkitManager()
mgr.base_configuration = DESCRIPTOR_STRING
mgr.plugin_id = “basic.testplugin”
engine = mgr.bootstrap_engine(“tk-shell”)
tk = engine.sgtk
sg_asset = tk.shotgun.find_one(“Asset”, [[“id”, “is”, 100]])
tk.create_filesystem_structure(“Asset”, sg_asset[“id”])
However, I keep running into a stack trace when trying to run this code in different Python environments. Has anyone else faced a similar issue or have any suggestions on what might be going wrong?
Thanks in advance for your help!
Regards
Darshan Hiranandani
It would help if you could post the stacktrace, please use the code block feature to post this so it formats nicely.
