Cuts still don't playback reliably
I reported this many years ago and it’s the reason we still haven’t been able to actually use Cut entities in production:
When playing back a cut entity in the browser it tends to flash the first frame of the reference media at each cut before showing the linked version. When stepping through frame by frame it behaves. I have seen this at different facilities on both OSX and linux.
Has anybody else come across this?
We are close to writing our own solution for reviewing cuts as this feature seems to have been abandoned ever since Autodesk took over. I remember the beta label got taken off the Cut feature but that was about the only update to it in about 10 years.
Would love to actually see this work reliably!
Hey @frank
On our end we have seen an improvement when using the new review app rather than the legacy player.
However, the best solution we still found (even though less versatile) was to make a mini-cut AMI that creates cuts of a few shots or an entire episode for review purposes and then manually dump the notes and annotations into each one of the shots. Not ideal though…
Hope it helps.
I agree that’s a major annoyance and makes the cut feature pretty much unusable for anything which is requiring a smooth playback.
@frank
When loading the Cut in RV, you will have a smooth playback - but need to wait for some loading and caching (Look ahead cache should be best here)
@alfonso
The Review app has the same frame blinks for us, but on top of this is way less performant and struggles to keep up with a constant 24fps.
I reported this and a bunch of other issues we are having to the team at Autodesk and looking forward to some fixes - will happen in the Review app I guess.
Best,
Tobi
It always happens, first run and all subsequent ones.
