Can't get thumbnails to load using GlobalSearchWidget
At this point I’m not getting any errors or warnings in the console:
self._task_manager = task_manager.BackgroundTaskManager(self)
        self._task_manager.start_processing()
        shotgun_globals.register_bg_task_manager(self._task_manager)
        globalSearchWidget = GlobalSearchWidget(self)
        globalSearchWidget.set_bg_task_manager(self._task_manager)
        globalSearchWidget.set_searchable_entity_types({"Asset": []})
The search lists assets, is filterable, etc, but I get no thumbnails:
My console output is:
2023-07-10 21:03:45,039 [   DEBUG] [PROXY] Task Manager: Started new background worker thread (num threads=1)
2023-07-10 21:03:45,040 [   DEBUG] [PROXY] Creating SG connection from ...
2023-07-10 21:03:45,050 [   DEBUG] [PROXY] create_sg_connection: 0.000323s
2023-07-10 21:03:45,405 [   DEBUG] [PROXY] Starting to download new metaschema from ShotGrid...
2023-07-10 21:03:47,963 [   DEBUG] [PROXY] Metaschema arrived from ShotGrid...
2023-07-10 21:03:47,971 [   DEBUG] [PROXY] Saving schema to '/Users/jherrera/Library/Caches/Shotgun/wba/p327c2375.basic.desktop/fw-shotgunutils/sg_schema.pickle'...
2023-07-10 21:03:47,984 [   DEBUG] [PROXY] ...done
Is there anything else that needs to be done for thumbnails to work?
UPDATE: If I remove the set_searchable_entity_type({“Asset”: }) I get thumbnails, (but obviously not the filtering I need)
UPDATE UPDATE: Correction, those weren’t assets I was seeing with thumbnails. It seems versions get thumbnails, assets get nothing. I cleared the cache to no change
