8.90 Release Notes
Release date: September 28th, 2026 ET
We released the following updates since 8.89:
Improvements:
Column fields pinning:
  • Improved grid performance when pinning or unpinning columns on pages with a large number of rows. This reduces UI freezes and makes column pinning and unpinning more responsive on large datasets. [SG-44544]
Exclude Statuses from calculation feature:
  • Improved the Summary settings to make the Excluded Statuses option clearer. When the selected summary type does not support excluded statuses, the field is now displayed but disabled instead of being hidden. The information tooltip remains available to explain when the option can be used. [SG-44957]
Review Notes APP:
  • Improved the Version details layout in the Review Notes app to better accommodate Versions with long descriptions, making it easier to access and interact with Related Notes, Tasks, and Versions. [SG-29620]
  • Create Review Notes publish form layout
Administrators with Access admin functionality can now configure the Review Notes publish form per project or as a global default for the site.
To configure the publish form layout:
  1. In the Review Notes app, finish taking Notes and click Preview and Publish.
  2. In the Send Notes dialog, open the gear menu and select Configure layout….
  3. In the Field Properties dialog, select the fields you want in the layout. You can order the fields, choose to hide their label, or change the displayed label. Click Apply.
  4. Open the gear menu again and select Save Form for the current project, or Save Form as Global Default for the site-wide default.
To discard those changes and return to the last saved layout, open the gear menu and select Revert Form.
Documentation
To learn more, see Configure Entity Creation Forms and Review Notes App.
Bug Fixes:
Review Notes APP:
  • Fixed an issue in the Review Notes app where changing the sort order for Related Notes had no effect. Related Notes are now displayed according to the selected sort order. [SG-45006]
Miscellaneous:
  • Fixed an issue where the People - Permissions page displayed the API permissions description instead of the correct description. [SG-39424]
v8.90.0.0 (build b6b30b0)
Improvements:
  • Made infrastructure improvements to enhance the security and reliability of Flow Production Tracking.
v8.90.0.9973 (build 50c6127)
Improvements:
Make key fields stand out in a Fields widget
On Canvas pages, you can now make the fields in a Fields widget larger and color their values, so the most important information on a dashboard is visible at a glance.
In Design Page mode, enter edit mode on a Fields widget. Under Fields Settings, you’ll find two new settings:
  • Field Size: Choose Normal, Large, or Extra Large. The labels, values, and icons in the widget all scale together.
  • Value Text Color: Choose a color for the field values. Labels keep their default color. None returns to the default color.
These settings apply to every field in the widget. They don’t affect how fields appear elsewhere, such as formatting rules on grid pages.
Documentation
To learn more about Canvas page widgets, see Designing Canvas pages.
Set email notifications per group
Administrators can use Send Email Notifications on each group to reduce email when large groups are assigned work before it is distributed to individuals.
This setting is especially useful when you assign large, general groups to tasks or other entities before refining them down to individual users.
For example, you might assign the Animation group first. The Animation lead then reviews the tasks assigned to their department and hands them out to individual artists. By clearing Send Email Notifications for the group but not for the individual users, you avoid sending a lot of email for tasks that aren’t assigned to individuals yet.
To change email notifications for a group:
  1. Open Admin Menu > Groups.
  2. Select or clear Send Email Notifications.
    If you don’t see the column, it’s hidden: right-click any column and select Insert Column > Send Email Notifications.
New groups default to Send Email Notifications selected. When it’s cleared, members do not receive email notifications when work is assigned or addressed to that group. Each member must still have the relevant options enabled under Email Notifications on their Account Settings page when the group sends email.
If an entity is assigned or addressed to a user directly, that user still receives email notifications even when a group they belong to has Send Email Notifications cleared.
Documentation
To learn more, see Groups and Departments.
Copy and paste page filter
You can now copy a page filter from one page and paste it onto another page of the same entity type. Instead of rebuilding a complex set of filter conditions by hand on each page, set up the filter once and reuse it wherever you need it, even in other projects.
Note:
The copied filter is stored in your browser, so you can paste it only in the same browser, on the same site. Paste Filter is disabled if you haven’t copied a filter, or if the copied filter is from a different entity type.
How to copy and paste a page filter
To copy a page filter:
  1. In the Filter Panel, hover over the page filter to copy and click Edit.
  2. In the filter editor, click Copy.
To paste the page filter:
  1. Go to another page of the same entity type. For example, if you copied a filter from a Shots page, go to another Shots page.
  2. In the Filter Panel, click Paste Filter.
    The filter is added to the page as a new page filter and applied. If the page already has a filter with the same name, the pasted filter is named “[original name] Copy”.
  3. Save the page to keep the filter on the page.
When you paste a filter onto a page in a different project, project-related conditions, such as “current project”, are updated for the destination page.
Bug Fixes:
Review Notes App:
  • Fixed an issue in the Review Notes app where clicking directly into a shot’s note-taking field did not automatically update the right-side panel with the corresponding shot information and related tasks. The right-side panel now updates as expected when users select the note-taking field, without requiring an additional click outside the field. [SG-45323]
Pipeline Steps:
  • Fixed an issue in Flow Production Tracking where expanded Pipeline Step columns could overlap with pinned columns when “Show Page (Column) Summaries” was enabled. Columns now scroll correctly behind pinned columns without overlapping, ensuring proper display of information when scrolling horizontally. [SG-45408]
Page Export:
  • Fixed a regression where exporting CSV files through the API could fail for previously saved page layouts, returning an HTTP 500 error. API exports now work as expected for both existing and newly created page layouts. [SG-45518]
v8.90.0.10080 (build 2f4e480b31)
Improvements:
  • Introducing Autodesk Assistant
Autodesk Assistant is now available in Flow Production Tracking. Ask it how to do something, or ask about your own site’s data. You no longer need to dig through the help, filters, or reports to answer simple questions.
Note:
Autodesk Assistant is available only to cloud-based sites.
Autodesk Assistant launches with two capabilities:
  1. Help and support: Get answers to “How do I…” questions based on official Autodesk documentation. This is available to everyone.
  2. Data access (Tech Preview): Ask questions about your own site’s data, such as “What rigging tasks are due this week?”, “What versions are ready for review?”. This is off by default, and your site administrator decides who can use it.
Autodesk Assistant shows you only the data you already have permission to see, and it can’t create, edit, or delete anything on your site.
Documentation
For more information, see About Autodesk Assistant in Flow Production Tracking.
  • Added support for filtering calculated fields via the API
    Flow Production Tracking now supports using calculated fields as filter conditions in API queries, including sg.find() and sg.find_one().
    Previously, calculated fields could be retrieved through the API but could not be used in filters. This enhancement allows users to filter records based on calculated field values using supported filter operators. [SG-45305]
Bug Fixes:
Miscellaneous:
  • Fixed an issue where custom field labels configured using the “Override Field Label” option were not retained after closing and reopening an entity creation form. Custom field labels are now saved and displayed correctly when reopening the form or refreshing the page. [SG-35567]
  • Fixed an issue where editing filters on pages in Detail View containing multiple vertically arranged Grid widgets could cause the page to scroll unexpectedly and become unresponsive. Filters can now be edited without disrupting the page layout or requiring a refresh. [SG-45448]
  • Fixed an issue where numeric values in number range filters were not visible when using dark mode. Number range filters now display values correctly, ensuring they remain readable in dark mode. [SG-45481]
  • Fixed a regression where List fields containing many options did not automatically scroll to the closest matching value when typing. List fields now automatically scroll to display the closest match, eliminating the need to manually scroll through the available options. [SG-45597]
  • Fixed an issue where Grid widgets in Canvas Detail View could overlap the Page Filters panel, preventing users from interacting with certain filter controls. The Page Filters panel now displays correctly above widget content, allowing users to interact with all filter controls as expected. [SG-45729]
Tasks:
  • Fixed an issue where tasks with Start or End dates set far in the past could cause an internal server error when accessing pages containing the Tasks widget. Pages now load correctly regardless of how far in the past task dates are set. [SG-45277]
