Release date: December 15th, 2025 ET
We released the following updates since 8.80:
Improvements
Importer:
- Improved the importer’s error handling so that it provides a clearer, more specific message when a unique field rule is violated during record import. [SG-38565]
Bug Fix:
Entity Search:
- Fixed an issue where the “Exact matches only” search option did not function correctly in some cases. [SG-40968]
Statuses:
- Resolved an issue where the “Hide Status” button was incorrectly displayed and enabled on the Global entity page. [SG-40708]
Fields:
Fixed an issue where the default field value could revert to blank after being set. [SG-41191]
Fixed a regression where the Field Configuration menu for Date-type fields failed to load correctly. [SG-41240]
Tasks, Gantt chart:
- Resolved an issue where top-right corner icons were unclickable when a pop-up window overlapped an expanded Gantt widget, ensuring the icons remain accessible as expected. [SG-38436]
Playlists:
- Fixed a regression where retiring playlists triggered an unknown server connection error. Playlists can now be retired reliably without error. [SG-41063]
Context Menu:
- Fixed a regression where context menus appeared behind modal windows. [SG-41234]
Review Notes App:
- Fixed a regression where using the Ctrl + Enter keyboard shortcut caused the Review Notes app to freeze. [SG-41248]
Importer:
- Fixed an issue where the bulk importer failed to map headers and fields when processing files in Japanese. [SG-40752]
v8.81.0.8002 (build f73904aa24)
Improvements
The print function in Flow Production Tracking now provides a better printing experience for Gantt charts and other views.
Cleaner print interface
Redundant UI elements have been removed from canvas, detail, list, and thumbnail views when printing. The page name is now more prominent in the printed output, making it easier to identify printed pages.
Enhanced Gantt printing
Gantt chart printing has been improved to print the entire set of records, not just what’s visible on the screen. This ensures you can print complete Gantt charts with all your records, regardless of how many are displayed in the current view.
You can now sort note replies by their most recent activity, making it easier to follow active conversations and see the latest updates first.
The Note information panel now includes a Sort Replies drop-down that lets you toggle between Latest First and Oldest First sorting options.
Open a note in the note info panel.
Click the new Sort Replies drop-down.
Select either Latest First or Oldest First.
The replies automatically reorder based on your selection.
Documentation
To learn more about working with your Inbox and notes, check out our Inbox documentation and Notes documentation.
Enable API export for any grid page directly from Page Settings. Once enabled, the page becomes available for export through API endpoints in the CSV format, with all saved filters, sorting, and column configurations automatically applied. This is especially helpful if you want to set up automatic reports.
Note:
This feature lets you tag a page so that it’s exposed for exporting using the Flow Production Tracking API. The code to retrieve the CSV data through the API will need to be created by your development team. See the Python API or REST API documentation for details.
There are benefits to using the API CSV export over the manual method:
Automated data extraction: Programmatically export page data without manual intervention.
Consistent exports: Saved filters and sorting are automatically applied for consistent results.
Integration-friendly: Access page data through REST API or Python API for custom workflows.
Layout support: Export specific layouts when multiple layouts are available for a page.
Note:
API Export is available only for grid-type pages. You must the permissions to edit the Page Settings to use this feature.
To tag a page for API export:
Navigate to the grid page you want to enable for API export.
Open Page Settings from the page menu.
Toggle API Export to enable the page for API-based exports.
Configure your filters, sorting, and columns as needed.
Once enabled, any saved filters or sorting on the page are automatically applied to future API exports, ensuring consistent data extraction.
Documentation
